[Gdal-dev] C# Dataset not calling GDALClose()?
Simon Perkins
sy at perkins.net
Wed Jul 11 13:02:04 EDT 2007
Could you explain this DLL locking thing? It would seem to be a sad day
for shared libraries if only one executable could use them at a time! Or
is it an issue that executables don't pick up recent changes to the
shared library, preferring to use the OS cached version instead?
I think that OGRCleanupAll() only deletes the currently registered
drivers, no? Does it actually unload the shared library? Is there an
equivalent GDAL function, BTW, GDALDeregisterAll()?
Cheers,
Sy
Richard Matsunaga wrote:
> This would likely help me out a great deal, as well as anyone using GDAL
> inside of an ASP.NET web site.
> Cheers,
> Richard
>> -----Original Message-----
>> From: gdal-dev-bounces at lists.maptools.org
>> Frank,
>> OGRCleanupAll() is not exposed to SWIG right now. Should we
>> add this function to the interface?
>> Best regards,
>> Tamas
>> 2007/7/11, Frank Warmerdam <warmerdam at pobox.com>:
>>>> Thanks Tamas, I didn't look deep enough to see what was
>> happening in
>>>> the C++ code for Dataset.
>>>> My problem is that our application is an ASP.NET web site and as
>>>> soon as a class instantiates a GDAL or OGR object, the
>> GDAL dll gets
>>>> locked and is only released after some long period of
>> idle time or if iisreset is called.
>>>> This makes updating GDAL (or just republishing the entire
>> website) a
>>>> bit of a pain. I was initially worried that there may be a memory
>>>> leak in there as well, but that seems to not be the case.
>>>> The problem is easily reproduced using NUnit as well. Any
>> test case
>>>> that uses a GDAL resource will lock the GDAL dll as well.
>>>> I just tried calling Ogr.RegisterAll() and it is the cause of the
>>>> lock on the dll. There seems to be no way of releasing resources
>>>> initialized by RegisterAll(). Not surprisingly, this behaviour is
>>>> also flagged as a memory leak (albeit a small one) by
>> DevPartner when using OGR in an application.
>>> Richard / Tamas,
>>> I'm not clear on what this "DLL locking" is all about, but at the C
>>> level there is an OGRCleanupAll() function which will
>> deregister OGR
>>> drivers as well as cleanup some other memory allocations.
>>> Best regards,
>>> I set the clouds in motion - turn up | Frank Warmerdam,
>>> light and sound - activate the windows | http://pobox.com/~warmerdam
>>> and watch the world go round - Rush | President OSGeo,
>> http://osgeo.org
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070711/02f2d23c/attachment.html
