[Gdal-dev] gdal_translate Basic Usage / UTM to latlong
Michael84
michael.timo.welsch at gmx.de
Sun Jul 15 02:23:46 EDT 2007
You use the wrong command line tool...
You should use gdal_warp: "Warp an image into a new coordinate system"
Define the origin cs by -s_srs ... and the resulting cs by -t_srs (
http://www.gdal.org/gdalwarp.html )
John R. wrote:
> Tim Osborn wrote:
>> OK...this is what's going on.....
>> I'm pretty sure the image is projected in the Wisconsin Transverse
>> Mercator
>> coordinate system WTM83. You can read about it at
>> http://www.dnr.state.wi.us/maps/gis/wtm8391.html. They list the
>> parameters
>> there and an email address you can request a prj file. WTM83 is not the
>> same as regular old UTM NAD83. The EPSG number code for WTM83 is 3070.
>> Here are the parameters for WTM83:
> [snip]
> Thanks!
> I requested the prj file (says it is for ArcGIS). I had done a quick
> search for the EPSG number but did not find it. I used the parameters
> to construct this:
> -a_srs '+proj=tmerc +lat_0=0 +lon_0=-90 +x_0=520000 +y_0=-4480000
> +k=0.9996 +ellps=GRS80 +units=m +datum=NAD83 +no_defs'
> The results look pretty close. Thanks again!
> I just now tried 3070 and I dot get long and lat listed in gdalinfo
> output:
> Driver: GTiff/GeoTIFF
> Size is 10750, 8488
> Coordinate System is:
> PROJCS["unnamed",
> GEOGCS["NAD83",
> DATUM["unknown",
> SPHEROID["unretrievable - using
> WGS84",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","3070"]]
> Origin = (659653.722794383182190,352632.358040164515842)
> Pixel Size = (0.329187501713504,-0.329168110366799)
> Metadata:
> AREA_OR_POINT=Area
> TIFFTAG_XRESOLUTION=1200
> TIFFTAG_YRESOLUTION=1200
> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Corner Coordinates:
> Upper Left ( 659653.723, 352632.358)
> Lower Left ( 659653.723, 349838.379)
> Upper Right ( 663192.488, 352632.358)
> Lower Right ( 663192.488, 349838.379)
> Center ( 661423.106, 351235.369)
> Band 1 Block=10750x1 Type=Byte, ColorInterp=Red
> Band 2 Block=10750x1 Type=Byte, ColorInterp=Green
> Band 3 Block=10750x1 Type=Byte, ColorInterp=Blue
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
View this message in context: http://www.nabble.com/gdal_translate-Basic-Usage---UTM-to-latlong-tf4065198.html#a11600033
Sent from the GDAL - Dev mailing list archive at Nabble.com.
