[Gdal-dev] gdal_translate Basic Usage / UTM to latlong
Tim Osborn
tosborn at sbcglobal.net
Sun Jul 15 21:24:25 EDT 2007
>You use the wrong command line tool...
>You should use gdal_warp: "Warp an image into a new coordinate system"
>Define the origin cs by -s_srs ... and the resulting cs by -t_srs (
http://www.gdal.org/gdalwarp.html )
He wasn't trying to warp the image from one coordinate system to another.
He was trying to find the correct coordinate system for the image he had,
which contained georeferenced bounds but no projection information.
Gdal_translate was the correct utility to use to assign the srs.
View this message in context: http://www.nabble.com/gdal_translate-Basic-Usage---UTM-to-latlong-tf4065198.html#a11607889
Sent from the GDAL - Dev mailing list archive at Nabble.com.
