[Gdal-dev] Measured Values for Shapefile read & write
Dylan Beaudette
dylan.beaudette at gmail.com
Tue Jul 24 14:52:52 EDT 2007
Sounds like there was some kind of NADGRID mixup.... ? where you projecting
across datums?
cheers,
Dylan
On Tuesday 24 July 2007 11:34, Nelson, Dean wrote:
> Craig,
> We would like our product to ingest any type of shape file (projected or
> lat/lon) and be able to run with it. However, as in the "[Gdal-dev] Is
> ogr2ogr the tool to use?" thread, I have some shapefile data from the
> USGS/Hydro1k project that is projected from a point and all of the
> values in the polygons are x,y values. I needed to convert to a Lat/Lon
> shapefile. I did it via ogr2ogr and the resulting output was placed 17km
> north of reality.
> I was looking for a kludgy fudge factor ;-)
> Regards,
> Dean Nelson
> Enterprise Electronics Corp
> -----Original Message-----
> From: Craig Hunter [mailto:craigrthunter at gmail.com]
> Sent: Tuesday, July 24, 2007 12:52 PM
> To: Nelson, Dean
> Cc: gdal-dev at lists.maptools.org
> Subject: Re: [Gdal-dev] Measured Values for Shapefile read &
> write
> Dean,
> Are you referring to an offset, in the sense you have a point on
> a line and you want to project it 100 meters off to the left side (90
> degrees) of the line? In that case, no, but I'm pretty sure that can
> already be performed with the ogr library as it is now.
> I'm referring to measured values (M-values) that are included in
> the geometry and can be used for dynamic segmentation.
> (Sorry for the repeated message, I left the mailing list off my
> initial reply)
> On 7/24/07, Nelson, Dean <dean.nelson at eecradar.com> wrote:
> Craig,
> Would this be like a projected shape file (i.e. x,y off
> of a median) ?
> Regards,
> Dean Nelson
> From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Craig Hunter
> Sent: Tuesday, July 24, 2007 11:25 AM
> To: gdal-dev at lists.maptools.org
> Subject: [Gdal-dev] Measured Values for
> Hi,
> I performed a hack to the OGR source in order to
> read and write shapefiles with measured values. If others may find this
> of value, I'll work on a patch?
> Also, the SDE driver only provides read access.
> Is there some technical or proprietary issues with performing write
> access to SDE? or has this not been developed due to a lack of interest?
> Thanks,
> Craig Hunter.
