[Gdal-dev] BigTIFF support
Frank Warmerdam
warmerdam at pobox.com
Fri Jul 27 10:46:16 EDT 2007
Luis Viveros wrote:
> Hi all,
> I have tried to generate a big tiff file (~16GB) with the svn version.
> When trying to create the file with gdalwarp (with -co BIGTIFF=YES) it
> fails.
> I have tried both the internal libtiff and also the tiff-4.0.0alpha.
> When running the configure options --with-libtiff=internal or
> --with-libtiff=yes or even
> --with-libtiff=/usr/local/src/tiff-4.0.0alpha/libtiff, GDAL is
Luis,
Are you trying to point --with-libtiff at a libtiff build directory or
an installed directory? Normally you would build and install libtiff4
somewhere (perhaps /usr/local) and then configure GDAL using --with-libtiff
pointing to the installed directory.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
