[Gdal-dev] GDALScaledProgress confusion
Thu Jun 7 10:14:38 EDT 2007
Stefan Klug wrote:
> Hi,
> I'm trying to use GDALScaledProgress and GDALCreateScaledProgress and
> I'm a bit confused by its correct usage.
> The docs say at http://www.gdal.org/gdal_8h.html
> pScaledProgress = GDALCreateScaledProgress
> <http://www.gdal.org/gdal_8h.html#462c1d7aa414cdacd608d62e1830ef43>(
> 0.0, 0.5, pfnProgress, pProgressData );
> GDALDoLongSlowOperation( ..., GDALScaledProgressFunc, pProgressData );
> GDALDestroyScaledProgress
> <http://www.gdal.org/gdal_8h.html#f1ac4100ae77f94983d45a33fc1b6fcd>(
> pScaledProgress );
> shouldn't pScaledProgress be passed to GDALDoLongSlowOperation() instead
> of pProgressData?
> This is the way it is used in /frmts/gtiff/geotiff.cpp.
> I even got more confused when I read /frmts/gtiff/gt_overview.cpp where
> in line 330... it is used like this:
> pScaledProgressData =  GDALCreateScaledProgress( ...,pfnProgress,
> pProgressData );
> GDALRegenerateOverviews( ...,pfnProgress,pProgressData);
> GDALDestroyScaledProgress( pScaledProgressData );
> Here the scaled progress seems to be completely left out.
> To me it looks like a small bug...
> Would be nice if someone could shed some light on this.
Stefan,
You are completely correct.  I have corrected the documentation and it
should be reflected on the website in the upcoming hours.  It should be:
  *   int MyOperation( ..., GDALProgressFunc pfnProgress, void *pProgressData );
  *       void *pScaledProgress;
  *       pScaledProgress = GDALCreateScaledProgress( 0.0, 0.5, pfnProgress,
  *                                                   pProgressData );
  *       GDALDoLongSlowOperation(...,GDALScaledProgressFunc, pScaledProgress );
  *       GDALDestroyScaledProgress( pScaledProgress );
  *       pScaledProgress = GDALCreateScaledProgress( 0.5, 1.0, pfnProgress,
  *                                                   pProgressData );
  *       GDALDoAnotherOperation(..., GDALScaledProgressFunc, pScaledProgress );
  *       return ...;
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
