[Gdal-dev] OCI support for Oracle 9i
Mateusz Loskot mateusz at loskot.net
Fri Jun 8 11:22:25 EDT 2007
NicoSIG wrote:
> Hi,
> I've the same problem, I tried with GDAL from SVN
> (gdal-svn-stable-2007.06.08.tar.gz), and the problem is persistent.
> The version of Oracle seems correctly detected. Please, could you
> regenerate the ./configure script for the next stable svn version ?
If you use SVN, you can regenereate ./configure yourself using
autogen.sh. Just run
$ ./autogen.sh
and you should get fresh version of ./configure.
Could you confirm if the problem vanished/still exists after you
regenerate the configure script?
I submitted ticket so we don't mis this task for next stable release:
http://trac.osgeo.org/gdal/ticket/1661
Cheers
Mateusz Loskot
http://mateusz.loskot.net
