[Gdal-dev] OCI support for Oracle 9i
NicoSIG nicolasgabarron at yahoo.fr
Fri Jun 15 02:09:13 EDT 2007
I tried that, but the shell send an error message:
+ aclocal -I ./m4
./autogen.sh: aclocal: not found
+ autoconf
./autogen.sh: autoconf: not found
What are those executables ?
Do I install them, or where can I find them ?
In the svn distribution, there is a file aclocal.m4.
What is this file ?
Thanks,
Nico
Mateusz Loskot wrote:
> NicoSIG wrote:
>> Hi,
>> I've the same problem, I tried with GDAL from SVN
>> (gdal-svn-stable-2007.06.08.tar.gz), and the problem is persistent.
>> The version of Oracle seems correctly detected. Please, could you
>> regenerate the ./configure script for the next stable svn version ?
> If you use SVN, you can regenereate ./configure yourself using
> autogen.sh. Just run
> $ ./autogen.sh
> and you should get fresh version of ./configure.
> Could you confirm if the problem vanished/still exists after you
> regenerate the configure script?
> I submitted ticket so we don't mis this task for next stable release:
> http://trac.osgeo.org/gdal/ticket/1661
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
View this message in context: http://www.nabble.com/OCI-support-for-Oracle-9i-tf3757272.html#a11133710
Sent from the GDAL - Dev mailing list archive at Nabble.com.
