[Gdal-dev] OCI support for Oracle 9i
Mateusz Loskot mateusz at loskot.net
Fri Jun 15 04:12:13 EDT 2007
NicoSIG wrote:
> Hi,
> I tried that, but the shell send an error message:
> + aclocal -I ./m4
> ./autogen.sh: aclocal: not found
> + autoconf
> ./autogen.sh: autoconf: not found
> What are those executables ?
These are part of so called GNU autotools.
> Do I install them, or where can I find them ?
Yes, you need to install autoconf, automake and libtool packages.
> In the svn distribution, there is a file aclocal.m4.
> What is this file ?
This is a local library of autoconf/m4 macros.
You don't need to do anything with this file.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
