[Gdal-dev] support for gpx and osm formats
Jachym Cepicky jachym.cepicky at gmail.com
Mon Jun 11 01:49:33 EDT 2007
Thanks for this comprehensive answer.
Jachym
Mateusz Loskot píše v Po 11. 06. 2007 v 07:39 +0200:
> Jachym Cepicky wrote:
> > Hi, I'm wondering, how difficult it would be, to add support for gpx
> > [1] and osm [2]. Would this be possible?
> Jachym,
> Recently, I've been thinking about these formats as well.
> Also, there is another interesting format called Polish Format (PFM) [1]
> which is used, among others, by OSM-like project in Poland called UMP.
> The GPX format was discussed in March:
> http://lists.maptools.org/pipermail/gdal-dev/2007-March/012099.html
> and as you can see the idea meets favouritism:
> http://lists.maptools.org/pipermail/gdal-dev/2007-March/012103
> The OSM format support in OGR is also under consideration by OSM community:
> http://lists.maptools.org/pipermail/gdal-dev/2007-May/013228.html
> >From my side, I think I could some help in conceptual and testing parts,
> I can help with incorporating new drivers into GDAL/OGR.
> Also, I could help with coding, though in some limited way.
> BTW, Jens Oberender is working on the KML driver for OGR so he is
> playing with XML data in OGR pretty much. I believe it would be
> reasonable to use this analysis, notes and experience for other
> XML-based formats:
> http://trac.osgeo.org/gdal/wiki/SoCKMLRead
> [1] From cGPSMapper manual:
> Polish Format is a convenient, text based, format used for saving map
> information on a computer and transferring map information between
> computer programs.
> Cheers
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
	=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
	=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070611/396abe6c/attachment.bin
