[Gdal-dev] Does GeoTIFF support LocalCS?
Frank Warmerdam
warmerdam at pobox.com
Sun Jun 24 18:51:11 EDT 2007
Ray Gardener wrote:
> Has anyone been able to use local CS with GeoTIFF? The best I can get
> GDAL to do is write an associated .tfw file out okay, but when reading
> back in, GetProjectionRef() in 1.4.1 returns
> GEOGCS["unnamed", DATUM["unknown",
> SPHEROID["unretrievable... UNITS["degrees"...
> Since the units (in my case, meters) are replaced with degrees,
> intepreting a "null" geogcs as localcs doesn't help.
> Does the GeoTIFF format support localcs? If so, I'd prefer to mod the
> driver to actually handle it.
Ray,
I suspect you are correct about LOCALCS support in geotiff. My intention
is that LOCAL_CS should translate to geotiff as a geotransform
matrix and linear units specified in the file. If that isn't happening
it is a bug and I'd appreciate your filing the specifics of what you see.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
