[Gdal-dev] s 57 data reader in java
Andrea Aime
aaime at openplans.org
Mon Jun 25 02:33:37 EDT 2007
kevser sonmez ha scritto:
> hi there,
> I want to ask whether any of you know a java library to read the s-57
> data? Just like the ogr which is a C++ API.
> Or is it possible to write the user interface in java and use the ogr as
> the data reader, if so how?
Have a look at the OGR java bindings, they should give you
what you're asking for. There is also a (very experimental) module
in Geotools that uses the OGR java bindings to expose OGR as a datastore
(it's there sitting on gt2 trunk).
Cheers
Andrea
