[Gdal-dev] s 57 data reader in java
Mateusz Loskot
mateusz at loskot.net
Mon Jun 25 02:39:17 EDT 2007
kevser sonmez wrote:
> hi there,
> I want to ask whether any of you know a java library to read the s-57 data?
> Just like the ogr which is a C++ API.
> Or is it possible to write the user interface in java and use the ogr as
> the data reader, if so how?
There are SWIG binginds to GDAL for number of languages,
including Java:
http://trac.osgeo.org/gdal/wiki/GdalOgrInJava
As you will find out, Java bindings are not well documented,
so I'd also recommend to search through the gdal-dev list
archives:
http://news.gmane.org/gmane.comp.gis.gdal.devel
where you can find helpful details and hints.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
