[Gdal-dev] s 57 data reader in java
kevser sonmez kevsemola at gmail.com
Tue Jun 26 02:00:44 EDT 2007
hmm, here is another question;
is it possible for me to produce these java bindings using SWIG? [Cause I
cannot find them :( ] And if so, will the produced bindings be used as
flexible as the ones in c++?
Thanks a lot for answers to newbie questions :)
On 6/25/07, Mateusz Loskot <mateusz at loskot.net> wrote:
> kevser sonmez wrote:
> > hi there,
> > I want to ask whether any of you know a java library to read the s-57
> data?
> > Just like the ogr which is a C++ API.
> > Or is it possible to write the user interface in java and use the ogr as
> > the data reader, if so how?
> There are SWIG binginds to GDAL for number of languages,
> including Java:
> http://trac.osgeo.org/gdal/wiki/GdalOgrInJava
> As you will find out, Java bindings are not well documented,
> so I'd also recommend to search through the gdal-dev list
> archives:
> http://news.gmane.org/gmane.comp.gis.gdal.devel
> where you can find helpful details and hints.
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070626/2290d76c/attachment.html
