[Gdal-dev] GEOS precision model?
Howard Butler
hobu.inc at gmail.com
Tue Jun 26 14:19:50 EDT 2007
Ari,
I've had similar problems, and I think there's been other GEOS users
with the same. The options are quite limited however:
-- Make sure you are using the robust operations (see the C++ header
files for details on what needs to be called) in the latest release
candidate. I don't think OGR uses these by default right now.
-- Tweak your precision models until you find something that works
consistently and good enough.
-- Use a computational geometry library that does real math like CGAL
or LEDA (I ended up taking this option).
-- Inject QD into GEOS to bump the precision up and at a likely cost
in performance <http://crd.lbl.gov/~dhbailey/mpdist/>. I don't know
how challenging this would be, but I suspect others would be
interested in it.
Howard
On Jun 26, 2007, at 11:18 AM, Ari Jolma wrote:
> I'm doing some rather heavy duty geocomputation with OGR (via Perl
> module Geo::OGR of course), mainly intersections. I run into a
> problem, where GEOS throws a topology exception since the vertices
> of the two geometries are very close to each other (6 digits same,
> then differences).
> I'm no GEOS guru, but it seems there is a possibility to improve
> the robustness of overlay operations with precision models(?). I
> think they could be useful for me now.
> Is there a way to take advantage of what GEOS offers (and what does
> it really offer, if I could have a quick lesson...) via OGR? And if
> not, would it be difficult to hack it in?
> Regards,
> Ari
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
