[Gdal-dev] OGROpen and delete
Andrew Bell andrew.bell.ia at gmail.com
Fri Jun 29 15:59:02 EDT 2007
The documentation for OGROpen says that the data source should be
deleted with "delete".  But the type OGRDataSourceH is really a void *
and you can't delete a void *.  What type do I have to cast the result
of OGROpen to in order to delete the source?
Thanks,
Andrew Bell
