[Gdal-dev] OGROpen and delete
Howard Butler
hobu.inc at gmail.com
Fri Jun 29 16:34:18 EDT 2007
Andrew,
The function to use is OGRReleaseDataSource (at least this is what
the SWIG bindings do). I'll update the doc...
Howard
On Jun 29, 2007, at 2:59 PM, Andrew Bell wrote:
> Hi,
> The documentation for OGROpen says that the data source should be
> deleted with "delete". But the type OGRDataSourceH is really a void *
> and you can't delete a void *. What type do I have to cast the result
> of OGROpen to in order to delete the source?
> Thanks,
> Andrew Bell
> andrew.bell.ia at gmail.com
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
