[Gdal-dev] problem with C# SWIG wrapper
Mateusz Loskot
mateusz at loskot.net
Fri Mar 2 16:43:34 EST 2007
Richard Matsunaga wrote:
> I get the same error (without the extended info) when I try to run the
> GDALColorTable.exe that gets created with the build.
Richard,
Do you run it on Linux or Windows?
> Is there some config that I must have missed?
I'll try to test it on my workstations today.
> I think there is a need for a single wiki page for documenting the setup
> for using the C# wrappers along with common pitfalls.
Good point.
I'm sure we will set up one on the Trac.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
