[Gdal-dev] problem with C# SWIG wrapper
Tamas Szekeres szekerest at gmail.com
Fri Mar 2 16:50:33 EST 2007
Would you make the tests with the latest SVN or the nightly build?
Apparently some of the dll-s might not be available to load for your
application. You might want use Sysinternals filemon to check which
files could not actually be loaded.
'make test' invokes the application in the same directory as the
dependent dll-s reside.
Best regards,
Tamas
2007/3/2, Richard Matsunaga <richard.matsunaga at waypointinfo.com>:
> Hi all,
> I've just started using the SWIG-generated C# wrapper and can't get it to
> work. The build seems to run fine, as do the tests, but when actually trying
> to use the resulting library, I get the following:
> System.TypeInitializationException : The type initializer
> for 'GDAL.gdalconst' threw an exception.
>   ----> System.TypeInitializationException : The type
> initializer for 'GDAL.gdalconstPINVOKE' threw an exception.
> initializer for 'SWIGExceptionHelper' threw an exception.
>   ----> System.DllNotFoundException : Unable to load DLL
> 'gdal_gdalconst_wrap': The specified module could not be found. (Exception
> from HRESULT: 0x8007007E)
> I get the same error (without the extended info) when I try to run the
> GDALColorTable.exe that gets created with the build.
> Is there some config that I must have missed? I think there is a need for a
> single wiki page for documenting the setup for using the C# wrappers along
> with common pitfalls.
> Thanks,
> Richard
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
