[Gdal-dev] Linking the GDAL lib to a Visual C++ 6 project
Arnaud
beaudele at yahoo.fr
Mon Mar 5 06:02:41 EST 2007
Hello,
I imported the GDAL lib to a vc6 project. I just want to import many DEM files
in order to be able to get the altitude of any point on the earth.
But whenever I try to include the gdal_priv.h file, I get several errors:
<<my project directory>>\gdal\include\cpl_string.h(218) : error C2220: warning
treated as error - no object file generated
<<my project directory>>\gdal\include\cpl_string.h(218) : warning C4097:
typedef-name 'string' used as synonym for class-name 'basic_string<char,struct
std::char_traits<char>,class std::allocator<char> >'
<<my project directory>>\gdal\include\cpl_string.h(219) : warning C4097:
c:\program files\microsoft visual studio\vc98\include\memory(16) : error
C2059: syntax error : 'string'
c:\program files\microsoft visual studio\vc98\include\memory(17) : error
C2091: function returns function
C2809: 'operator new' has no formal parameters
c:\program files\microsoft visual studio\vc98\include\memory(20) : error
C2954: template definitions cannot nest
c:\program files\microsoft visual studio\vc98\include\vector(249) : warning
C4663: C++ language change: to explicitly specialize class template 'vector'
use the following syntax:
template<> class vector<bool,class std::allocator<unsigned int> > ...
In fact the warning level is set to the highest. This cannot be change.
Do you have any clue what I can do to solve this?
Thanks in advance.
Arnaud
