[Gdal-dev] Linking the GDAL lib to a Visual C++ 6 project
Mateusz Loskot mateusz at loskot.net
Tue Mar 6 02:51:53 EST 2007
Arnaud wrote:
> Hello,
> I imported the GDAL lib to a vc6 project. I just want to import many DEM files
> in order to be able to get the altitude of any point on the earth.
> But whenever I try to include the gdal_priv.h file, I get several errors:
> <<my project directory>>\gdal\include\cpl_string.h(218) : error C2220: warning
> treated as error - no object file generated
> <<my project directory>>\gdal\include\cpl_string.h(218) : warning C4097:
> typedef-name 'string' used as synonym for class-name 'basic_string<char,struct
> std::char_traits<char>,class std::allocator<char> >'
> <<my project directory>>\gdal\include\cpl_string.h(219) : warning C4097:
> c:\program files\microsoft visual studio\vc98\include\memory(16) : error
> C2059: syntax error : 'string'
> c:\program files\microsoft visual studio\vc98\include\memory(17) : error
> C2091: function returns function
> C2809: 'operator new' has no formal parameters
> c:\program files\microsoft visual studio\vc98\include\memory(20) : error
> C2954: template definitions cannot nest
> c:\program files\microsoft visual studio\vc98\include\vector(249) : warning
> C4663: C++ language change: to explicitly specialize class template 'vector'
> use the following syntax:
>         template<> class vector<bool,class std::allocator<unsigned int> > ...
> In fact the warning level is set to the highest. This cannot be change.
> Do you have any clue what I can do to solve this?
Are you using GDAL in MFC-based application?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
