[Gdal-dev] Storing 2.5D elevations in Mapinfo .tab files
Howard Urmenyi
howard.urmenyi at geospatialvision.com
Fri Mar 9 09:34:20 EST 2007
I've been using OGR to read/write MapInfo .tab files with 2D lines and
string fields successfully (thanks!) but I can't figure out how to save
out per-vertex elevation data.
I've tried setting OGRLineString coordinate dimensions to "3" and
saving out the .tab, but on reading it back it's always been flattened
to 2D
Do you know of any way to store 3D or 2.5D lines in a MapInfo .tab file?
Thanks and regards,
Howard
________________________________________________________________________
This e-mail, and any attachment, is confidential. If you have received it in error, do not use or disclose the information in any way, notify me immediately, and please delete it from your system.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070309/5dd02778/attachment.html
