[Gdal-dev] GDALOpenInfo->fp == NULL for large files?
Tue Mar 13 01:05:49 EDT 2007
Nick Bower wrote:
> Hi - thanks Frank, but I did mention in my original post that the file
> is just 85 megabytes big.  The platform is a HPC style Itanium cluster
> running SuSe by the way.  Commenting out the fp = NULL in the block in
> which VSIFOpenL happens makes things work, including the L1B driver's
> use of VSIFOpen.  But the real issue would seem to be why is errno being
> set by VSIFOpen?  I may be a Python coder, but what guarantees that
> fp!=NULL && errno != (27, ENOENT, 79) simultaneously?  Convention
> (whatever I'm doing, I seem to be breaking it)?  Perhaps the logic here
> needs to be better.
>             fp = VSIFOpen( pszFilename, "rb" );
>             if( fp != NULL )
>                 nHeaderBytes = (int) VSIFRead( pabyHeader, 1, 1024, fp
>                 VSIRewind( fp );
>             else if( errno == 27 /* "File to large" */
>                      || errno == ENOENT
>                      || errno == 79 /* EOVERFLOW - value too large */ )
>                 // Why are we in here if VSIFOpen works elsewhere???
Nick,
Sorry, that is what I get for reading quickly and leaping to assumptions.
I'm left quite confused.  Are you suggesting that in the above context
fp is return as non-NULL by VSIFOpen(), but we end up in the errno==27
logic anyways?  That doesn't seem to make sense.
I'm at a loss.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
