Thanks for Answer: [Gdal-dev] How to custom my "Projected Coordinate Systems" inOGR
Thu Mar 15 21:20:44 EDT 2007
ÚO½¨Ã÷ wrote:
> Hi,Frank:
> Thanks for your reply.I will modify my code follow your advice.
> And i have another question:
> Is under the $GDAL_DATA$ directory have a file to describe which
> projection hava how many parameter as well as their name,function. I
> want give a common custome projection UI,if have the file i mention
> above it can make me dynamicly control the Form style. If don't have
> this file,should i control the UI according the projection various by
> enumerate their parameter ?
> hope your next reply.
ÚO½¨Ã÷,
There is no file in $GDAL_DATA$ for this, but at the API
level we do have the following functions to fetch a list of
projection methods, and the corresponding parameter list.
I don't think I have been maintaining it very well, so there
may be a few omissions, but it is intended to make it possible
to build a GUI that "automatically" supports all the projection
methods of the current GDAL/OGR.
/*      Projection transform dictionary query.                */
char CPL_DLL ** OPTGetProjectionMethods();
char CPL_DLL ** OPTGetParameterList( const char * pszProjectionMethod,
                             char ** ppszUserName );
int CPL_DLL OPTGetParameterInfo( const char * pszProjectionMethod,
                                 const char * pszParameterName,
                                 char ** ppszUserName,
                                 char ** ppszType,
                                 double *pdfDefaultValue );
There appears to be some documentation on this page:
http://www.gdal.org/ogr/ogr__srs__api_8h.html
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
