[Gdal-dev] Problem reading shapefiles with upper and lowercase
extensions, bug?
Alexandre Leroux
alexandre.leroux at ec.gc.ca
Fri Mar 16 09:35:44 EDT 2007
Hi list,
A colleague stumbled on the following problem: OGR failed to read the
shapefile.PRJ associated to a shapefile.shp file. The workaround is
simply renaming the ".PRJ" to lowercase. Shouldn't OGR read it whatever
the case? Could this be considered a bug?
Have a nice Friday,
Alex :-)
Alexandre Leroux, M.Sc., Ing.
Environnement Canada / Environment Canada
Centre météorologique canadien / Canadian Meteorological Centre
Division de la réponse aux urgences environnementales /
Environmental Emergency Response Division
