[Gdal-dev] Problem reading shapefiles with upper and lowercase
extensions, bug?
Mateusz Loskot
mateusz at loskot.net
Fri Mar 16 11:21:58 EDT 2007
Alexandre Leroux wrote:
> Hi list,
> A colleague stumbled on the following problem: OGR failed to read the
> shapefile.PRJ associated to a shapefile.shp file. The workaround is
> simply renaming the ".PRJ" to lowercase. Shouldn't OGR read it
> whatever the case? Could this be considered a bug?
Alexandre,
Yes, it seems the small bug occure on case sensitive file systems.
Could you please submit a bug report and assign it to me
with my e-mail mateusz (at) loskot (dot) net? Thanks!
Cheers
Mateusz Loskot
http://mateusz.loskot.net
