[Gdal-dev] Re: C# Geometry Classes?
Tamas Szekeres
szekerest at gmail.com
Wed Mar 21 18:33:01 EDT 2007
Simon,
Currently - for all of the SWIG bindings - you can access the various
geometry types through the Geometry base class therefore you cannot do
much derived class specific operations. However, indeed, it would be a
nice addition to support separate classes for the geometry types like
Polygon, LineString, MultiPoligon etc.
This kind of implementation requires a widespead decision of the
developers since a C# only implementation would bring in a great
degree of divergence between the languages that should be highly
avoided.
Best regards,
Tamas
2007/3/21, Simon Perkins <sy at perkins.net>:
> Simon Perkins wrote:
> > Do the latest C# bindings include the concrete OGR geometry classes? I
> > just realized that my current version doesn't have things like
> > OGR.Polygon, so I can't actually access the points in a Feature via
> > OGR (if I'm not missing something).
> OK, just looked in a bit more detail - so, it appears that the C#
> bindings follow the C API more than the C++ one, with methods like
> Geometry.GetPoint() and so on. So, if the geometry is a polygon, how do
> we access the inner and outer rings?
> Are we likely to see OGR.Polygon, OGR.LineString and so forth at any point?
> Cheers,
> Simon
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
