[Gdal-dev] problem with gdalwarp (resulting images are not
georeferenced properly)
rumicuna4-2007 at yahoo.com
Fri May 4 16:58:59 EDT 2007
Hello all,
I am getting incorrect results when I use gdalwarp and cannot figure out what I am doing wrong. The warping looks perfect, but the coords embedded in the resulting geotiff are shifted south so the resulting image does not show up correctly when overlayed on a map. I tried with other programs and did not have the same problem, I would rather use gdal because of the great interpolation capabilities.
The command I am using is:
gdalwarp.exe -rc -s_srs "+proj=latlong +datum=WGS84" -t_srs "+proj=ortho +datum=WGS84 +lon_0=11.618610 +lat_0=56.154163" -co INTERLEAVE=PIXEL Denmark.InitialCrop.tif Denmark.Warped.tif
I have placed the image I am trying to warp and the resulting file here:
http://ecovagabond.com/gis/Denmark.InitialCrop.tif
http://ecovagabond.com/gis/Denmark.Warped.Gdal.tif
In case this is helpful I am also including below the results of running gdalinfo on both files.
I am using a freshly installed version of FWTools1.3.0 on a WindowsXP machine.
The initial file was created by running gdal_translate on an image of the world.
Any help would be greatly appreciated.
Thank you,
-Diego
gdalinfo.exe Denmark.InitialCrop.tif
Driver: GTiff/GeoTIFF
Size is 988, 433
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (7.520833333333343,57.937500000000000)
Pixel Size = (0.008333333333333,-0.008333333333333)
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Left ( 7.5208333, 57.9375000) ( 7d31'15.00"E, 57d56'15.00"N)
Lower Left ( 7.5208333, 54.3291667) ( 7d31'15.00"E, 54d19'45.00"N)
Upper Right ( 15.7541667, 57.9375000) ( 15d45'15.00"E, 57d56'15.00"N)
Lower Right ( 15.7541667, 54.3291667) ( 15d45'15.00"E, 54d19'45.00"N)
Center ( 11.6375000, 56.1333333) ( 11d38'15.00"E, 56d 8'0.00"N)
Band 1 Block=988x8 Type=Byte, ColorInterp=Red
Band 2 Block=988x8 Type=Byte, ColorInterp=Green
Band 3 Block=988x8 Type=Byte, ColorInterp=Blue
gdalinfo.exe Denmark.Warped.Gdal.tif
Size is 888, 679
PROJCS["unnamed",
GEOGCS["WGS 84",
DATUM["WGS_1984",
AUTHORITY["EPSG","4326"]],
PROJECTION["Orthographic"],
PARAMETER["latitude_of_origin",56.154163],
PARAMETER["central_meridian",11.61861],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-266952.302792707110000,186552.524760038390000)
Pixel Size = (603.704336812790870,-603.704336812790870)
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Left ( -266952.303, 186552.525) ( 7d 7'11.01"E, 57d55'29.90"N)
Lower Left ( -266952.303, -223362.720) ( 7d31'40.14"E, 54d15'29.98"N)
Upper Right ( 269137.148, 186552.525) ( 16d 9'15.23"E, 57d55'25.29"N)
Lower Right ( 269137.148, -223362.720) ( 15d44'34.17"E, 54d15'25.78"N)
Center ( 1092.423, -18405.098) ( 11d38'10.15"E, 56d 9'59.87"N)
Band 1 Block=888x3 Type=Byte, ColorInterp=Red
Band 2 Block=888x3 Type=Byte, ColorInterp=Green
Band 3 Block=888x3 Type=Byte, ColorInterp=Blue
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070504/ed8ab4c1/attachment.html
