[Gdal-dev] RFC 12: Improved File Management
Frank Warmerdam
warmerdam at pobox.com
Mon May 7 13:47:45 EDT 2007
Ari Jolma wrote:
> Frank Warmerdam kirjoitti:
>> I normally think of OGRLayer's as being analygous to bands
> Hmm, I've been using OGROpen with a directory name instead of filename.
> Then I've been able to loop through all vector data layers (for example
> shapefiles) in that directory. I've sometimes wondered what happens if
> there are for example shapefiles _and_ mapinfo files in the same directory.
Ari,
I see what you mean. This is a convenience offered by some OGR drivers.
If a directory contains a mixture of shapefiles and mapinfo files any
attempt to open the directory will give you a shapefile datasource and
the mapinfo files will be ignored.
It's important to keep in mind that this "open a directory" support
is a feature of a driver, not OGR in general. Only a couple drivers
support this and it isn't always done in an equivelent approach.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
