[Gdal-dev] Re: Motion: Adopt RFC 12: Improved File Management
Frank Warmerdam
warmerdam at pobox.com
Wed May 9 10:52:50 EDT 2007
Daniel Morissette wrote:
> Frank Warmerdam wrote:
>> Doh! I just realized that my original contract delivery also included
>> a copy
>> operation. I would like to withdraw my original motion, and instead move
>> to adopt a revised version of RFC 12 which includes a Copy operator:
>> http://trac.osgeo.org/gdal/wiki/rfc12_filemanagement
>> The copy operator works similarly to rename, but doesn't alter the
>> source.
> Since the copy function is called pfnCopyFiles(), should we call the
> rename function pfnMoveFiles() instead of pfnRename(), just for
> consistency?
> Actually, at the higher level I see that you have GDALCopyDatasetFiles()
> and GDALRenameDataset() ... um ... why the "Files" suffix in one case
> and not the other?
Daniel,
I added the word Files to the Copy operation to try and clarify the
distinction between it and the CreateCopy() method which is a "data
model oriented" copy rather than a literal file copy.
I would agree that it is peculiar that rename and copy are not similarly
named in this regard.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
