[Gdal-dev] Read image file to Numpy, then output to image
Christopher Barker Chris.Barker at noaa.gov
Wed May 9 14:03:58 EDT 2007
Nate Jennings wrote:
> Thank you.  After the print, I get:
> ['__builtins__', '__doc__', '__file__', '__name__', '__path__']
> This is it.
OK. it looks like you got the gdal package, but nothing it it. Darn.
> If you have a recommended gdal install (.exe) I might try,
> then I will do this.
Sorry I'm Windows-clueless at the moment -- can someone help this guy?
By the way, it looks like you're only replying to me -- which is the
default for the mailing list. I'd make sure this gets to the list --
someone there can be fr more helpful than me.
-CHB
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
