[Gdal-dev] Re: Problem using EPSG in C#
Tomas R
monshi at home.se
Thu May 10 05:35:06 EDT 2007
One problem - where do I find the source-files for the CSharp bindings?
I have managed to download and compile the source for GDAL but I find no
C#-dlls being generated and when I try running the makefile found in
Swig/Csharp I get an error. Probably because all I've got is a couple of
makefiles.
/tomas
Tamas Szekeres skrev:
> Tomas,
> You'll have to comment out the
> CSHARP_STATIC_LINKAGE = YES
> in csharp.opt and recompile the C# interface. Using this setting the
> csharp dll-s will link against the gdal14.dll so the
> PushFinderLocation and ImportFromEPSG will operate on the same global
> data. In the future I consider to use this setting as the default
> option.
> BTW: I would propose to use the latest development version of the C#
> related stuff. There were some fundamental changes in the interface
> that might cause some changes in the existing code. For more
> information see:
> http://trac.osgeo.org/gdal/wiki/GdalOgrCsharpVersions
> You might also use the binaries of the latest FWTools
> http://test.gdal.org/fwtools/FWTools130.exe
> and replace the *_wrap.dll-s and *_csharp.dll-s inside with the
> compiled version.
> Best regards,
> Tamas
> 2007/5/9, Tomas R <monshi at home.se>:
>> >> Tomas,
>> >> Thank you for the detailed analysis of the problem. I'm working on
>> >> this issue and will notify you if I have further information. In the
>> >> meantime I would suggest to submit a ticket including the example
>> >> code.
>> >> http://trac.osgeo.org/gdal/newticket
>> >> Best regards,
>> >> Tamas Szekeres
>> > Ok, done that. Included as specific info as I could.
>> > You should be able to reproduce it.
>> > Thanks
>> > Tomas
>> For those interested the ticket number is 1621. Just click the link to
>> read the ticket:
>> http://trac.osgeo.org/gdal/ticket/1621
>> Hope this will be solved sometime soon. I have other things to attack in
>> my code so just knowing this is under review is, for now, good enough
>> for me.
>> /Tomas
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
