[Gdal-dev] Re: Problem using EPSG in C#
Tomas R
monshi at home.se
Thu May 10 07:02:16 EDT 2007
Problem solved... Found a page on the wiki:
http://trac.osgeo.org/gdal/wiki/GdalOgrCsharpCompile
I now something to play around with, seems the compilation completed
without errors.
/Tomas
Tomas R skrev:
> One problem - where do I find the source-files for the CSharp bindings?
> I have managed to download and compile the source for GDAL but I find no
> C#-dlls being generated and when I try running the makefile found in
> Swig/Csharp I get an error. Probably because all I've got is a couple of
> makefiles.
> /tomas
> Tamas Szekeres skrev:
>> Tomas,
>> You'll have to comment out the
>> CSHARP_STATIC_LINKAGE = YES
>> in csharp.opt and recompile the C# interface. Using this setting the
>> csharp dll-s will link against the gdal14.dll so the
>> PushFinderLocation and ImportFromEPSG will operate on the same global
>> data. In the future I consider to use this setting as the default
>> option.
>> BTW: I would propose to use the latest development version of the C#
>> related stuff. There were some fundamental changes in the interface
>> that might cause some changes in the existing code. For more
>> information see:
>> http://trac.osgeo.org/gdal/wiki/GdalOgrCsharpVersions
>> You might also use the binaries of the latest FWTools
>> http://test.gdal.org/fwtools/FWTools130.exe
>> and replace the *_wrap.dll-s and *_csharp.dll-s inside with the
>> compiled version.
>> Best regards,
>> Tamas
>> 2007/5/9, Tomas R <monshi at home.se>:
>>> >> Tomas,
>>> >> Thank you for the detailed analysis of the problem. I'm working on
>>> >> this issue and will notify you if I have further information. In the
>>> >> meantime I would suggest to submit a ticket including the example
>>> >> code.
>>> >> http://trac.osgeo.org/gdal/newticket
>>> >> Best regards,
>>> >> Tamas Szekeres
>>> > Ok, done that. Included as specific info as I could.
>>> > You should be able to reproduce it.
>>> > Thanks
>>> > Tomas
>>> For those interested the ticket number is 1621. Just click the link to
>>> read the ticket:
>>> http://trac.osgeo.org/gdal/ticket/1621
>>> Hope this will be solved sometime soon. I have other things to attack in
>>> my code so just knowing this is under review is, for now, good enough
>>> for me.
>>> /Tomas
>>> Gdal-dev mailing list
>>> Gdal-dev at lists.maptools.org
>>> http://lists.maptools.org/mailman/listinfo/gdal-dev
