[Gdal-dev] Re: Problem using EPSG in C#
Tomas R
monshi at home.se
Thu May 10 09:24:43 EDT 2007
I thought I had the issue solved, that I had managed to compile the
correct C# bindings and so on.
But, sadly no.
What have I got?
FWtools 3.0
Gdal source, from the latest Trunk
Got the whole SDK-kit from MS, Swig 1.3.31 and Visual Studio Express C++
I manage to compile the whole GDAL-project. I manage to compile C#
bindings with CSHARP_STATIC_LINKAGE = YES and CSHARP_STATIC_LINKAGE = NO
but NOT with it commented out.
The compile with CSHARP_STATIC_LINKAGE = NO do not seem to affect the
result as would be needed. When I try to set up a SpatialReference with
an EPSG-code I still get a 6.
With CSHARP_STATIC_LINKAGE commented out the compilation halts when
creating gdal_wrap.dll:
> LINK : gdal_wrap.dll not found or not built by the last incremental link; perfor
> ming full link
> Creating library gdal_wrap.lib and object gdal_wrap.exp
> gdal_wrap.obj : error LNK2019: unresolved external symbol _GDALIdentifyDriver at 8
> referenced in function "void * __cdecl IdentifyDriver(char const *,char * *)" (?
> IdentifyDriver@@YAPAXPBDPAPAD at Z)
> gdal_wrap.dll : fatal error LNK1120: 1 unresolved externals
> NMAKE : fatal error U1077: '"C:\Program\Microsoft Visual Studio 8\VC\BIN\link.EX
> E"' : return code '0x460'
> Stop.
Why is it never as simple? Do I miss something?
/Tomas
Tamas Szekeres skrev:
> Tomas,
> You'll have to comment out the
> in csharp.opt and recompile the C# interface. Using this setting the
> csharp dll-s will link against the gdal14.dll so the
> PushFinderLocation and ImportFromEPSG will operate on the same global
> data. In the future I consider to use this setting as the default
> option.
> BTW: I would propose to use the latest development version of the C#
> related stuff. There were some fundamental changes in the interface
> that might cause some changes in the existing code. For more
> information see:
> http://trac.osgeo.org/gdal/wiki/GdalOgrCsharpVersions
> You might also use the binaries of the latest FWTools
> http://test.gdal.org/fwtools/FWTools130.exe
> and replace the *_wrap.dll-s and *_csharp.dll-s inside with the
> compiled version.
> Best regards,
> Tamas
