[Gdal-dev] Re: Problem using EPSG in C#
Tomas R
monshi at home.se
Sat May 12 07:39:53 EDT 2007
Oh, did I post that version when I tried to go from WGS84 to WGS84. Have
tried it before and then it changed nothing but still a test if the call
works.
Tried your code and, no.. I have no idea why it won't work. But my guess
is something work with compilation of gdal... Perhaps. (some path that
perhaps needs to be set before compilation?)
Worth mentioning is perhaps that GDALinfo, the included example, work.
The include OSRTransform example give the same error as my own code.
Would have been a bit surprised if not.
It works to allocate the SpatialReferences and the CoordinateTransform,
it is the call to transform the two points that fails.
Call stack:
> [External Code]
> ogr_csharp.dll!OSGeo.OGR.CoordinateTransformation.TransformPoint(double[]
> argout = {Dimensions:[3]}, double x = 1620000.0, double y = 6597000.0,
> double z = 0.0) Line 57 + 0x2c bytes C#
> GdalTest1.exe!GdalTest.Form1.button5_Click(object sender = {Text
> = "button5"}, System.EventArgs e = {X = 54 Y = 11 Button = Left}) Line
> 101 + 0x2b bytes C#
> [External Code]
> GdalTest1.exe!GdalTest.Program.Main() Line 17 + 0x1a bytes C#
> [External Code]
As you can see it is runs from a Window Application but that should not
have anything to do with.
The whole exception. A short translation of the message is, as previous
said, " A try to read to read or write to protected memory. This
indicates often that another memory is damaged."
> System.AccessViolationException was unhandled
> Message="Det gjordes ett försök att läsa eller skriva till skyddat
> minne. Detta indikerar ofta att annat minne är skadat."
> Source="ogr_csharp"
> StackTrace:
> vid
> OSGeo.OGR.OsrPINVOKE.CoordinateTransformation_TransformPoint__SWIG_1(HandleRef
> jarg1, Double[] jarg2, Double jarg3, Double jarg4, Double jarg5)
> vid OSGeo.OGR.CoordinateTransformation.TransformPoint(Double[]
> argout, Double x, Double y, Double z) i c:\Documents and
> Settings\Tomas\Skrivbord\GDalDoc\trunk\gdal\swig\csharp\ogr\CoordinateTransformation.cs:rad
> 57
> vid GdalTest.Form1.button5_Click(Object sender, EventArgs e) i
> d:\Documents and Settings\Tomas\Mina dokument\Visual Studio
> 2005\Projects\GdalTest1\GdalTest1\code\Form1.cs:rad 101
I downloaded the latest trunk and compiled with no error. Set references
to the four CSharp-dlls and included gdal14.dll and the wrapper dlls in
the project, all files after compilation in same folder. But when I run
the code, same error.
And as said before: Environment to compile in is Visual Studio Express
C++, 2005 environment for developing is Visual Studio Express C# 2005.
Nothing strange.. Version 1.4.1 I have managed to compile and run... But
of course not EPSG-codes in v 1.4.1
Tamas Szekeres skrev:
> Tomas,
> I couldn't find out what is the actual value of your WGS variable in
> SpatialReference wgs84 = new SpatialReference(WGS);
> In addition CoordinateTransformation(wgs84, wgs84); doesn't seem to do
> anything with the coordinate values.
> Here is my equivalent code that worked:
> int rtX = 1620000;
> int rtY = 6597000;
> Gdal.SetConfigOption("GDAL_DATA",@"C:\Program
> Files\FWTools1.3.0\data");
> Gdal.PushFinderLocation(@"C:\Program
> SpatialReference source = new SpatialReference("");
> int res = source.ImportFromEPSG(3021);
> string srcTest, dstTest;
> source.ExportToWkt(out srcTest);
> Console.WriteLine(srcTest);
> SpatialReference wgs84 = new SpatialReference("");
> wgs84.SetWellKnownGeogCS("WGS84");
> wgs84.ExportToWkt(out dstTest);
> Console.WriteLine(dstTest);
> CoordinateTransformation toWGS = new
> CoordinateTransformation(source, wgs84);
> double[] data = new double[3];
> toWGS.TransformPoint(data, rtX, rtY, 0);
> Console.WriteLine(data[0].ToString() + " " +
> data[1].ToString());
> However your memory corruption issue is somewhat frustrating, do you
> have a call stack for this error?
> Best regards,
> Tamas
> 2007/5/11, Tomas R <monshi at home.se>:
>> I have received two answers in my mailbox but don't see them here. I
>> reply to one of them:
>> The code I use to produce the error is:
>> > int rtX = 1620000;
>> > int rtY = 6597000;
>> > @"C:\Program\FWTools1.3.0\data");
>> Gdal.PushFinderLocation(@"C:\Program\FWTools1.3.0\data");
>> > put(srcTest);
>> > put(dstTest);
>> > put(data[0].ToString() + " " + data[1].ToString());
>> Where Put is just a call to a routine which displays the text on screen.
>> Without gdal14.dll or all the wrapper dlls included in the project the
>> code halts at first call to Gdal. With the wrappers and the gdal dll
>> included in the project the SpatialRefernces are correctly initialized
>> (wgs from a WKT-string, just for testing, source from ESPG (have tested
>> other than RT90)) but instead it halts at call to TransformPoint. The
>> exceptions InnerException is null, error in OGR/OSR_sharp.dll. I have
>> tested with both reference to OGR and OSR.
>> I have also tried copying all dlls from FWTool to the project but with
>> no difference.
>> Thank you for your help! The time you take to clear this up is highly
>> appreciated!
>> Yours
>> Tomas
>> This was in answer to
>> > Could you post your example that produces this behaviour? I haven't
>> > found this issue when using a similar test you have mentioned.
>> > Tamas
>> Tomas R skrev:
>> > Again I was a bit to quick when reporting success.
>> > Yes, now I am able to create a SpatialReference from an EPSG code and
>> > from Proj4 (not tested WKT)
>> > And I am able to create a CoordinaTransform object from those
>> > spatialreferences.
>> > But I'm not able to perform an actual coordinate transformation, an
>> > exception is thrown (trying to read or write to protected (in
>> > ogr_sharp.dll).
>> > So, again I ask:
>> > Have I missed some step or is it still something in GDAL that doesn't
>> > work?
>> > /Tomas
>> > Tomas R skrev:
>> >> Ok Tamas, it kind of works...
>> >> I followed the steps you have described for me and those I found on
>> >> the Wiki:
>> >> 1: Downloaded latest trunk
>> >> 2: Compiled GDAL (how many of the steps must I do? All? Or just the
>> >> first, I guess just the first)
>> >> 3: Created the C# interface and compiled it.
>> >> 4: Copied the resulting *_wrap.dlls to Fwtool1.3.0\bin folder
>> >> 5: Added the new CSharp-dlls to my C# project.
>> >> 6: Checked that the system path contains FWTools1.3.0\bin folder
>> >> If I try running my project after those steps I get an exception when
>> >> trying to call GDAL, whatever *_wrap.dll that is called is not
>> >> found/not possible to load.
>> >> When I add the wrap-dlls to the "root" of my C#-project, no apparent
>> >> change.
>> >> When I copy the GDAL-dll to my projects root and include it in the
>> >> build, together with the wrap-dlls, it works!
>> >> But is this how it now is supposed to be? I guess I with this setup
>> >> can use GDALs basic function but all the functions which rely on
>> >> other libs (which I have not tested/any knowledge of yet) are not
>> >> available? For example reading and writing of GeoTiff images? (That
>> >> is possible via the C#-bindings?)
>> >> For now I think I'm content with coordinate translation but I think I
>> >> want to try how efficient GDAL is to use when importing maps of
>> >> different formats. It would be nice to be able to rip directly from
>> >> GeoTiff (or RIK) with GDAL.
>> >> Perhaps a bit OT but:
>> >> In basic it boils down to that I have now not a clear idea how to
>> >> distribute the plugin I am building. Demand that FWTools are
>> >> installed or include the nessecary dlls? O well, there is time left
>> >> to think about that.
>> >> /Tomas
