[Gdal-dev] Re: Problem using EPSG in C#
Tamas Szekeres
szekerest at gmail.com
Fri May 11 08:17:05 EDT 2007
2007/5/11, Tomas R <monshi at home.se>:
> Ok Tamas, it kind of works...
> I followed the steps you have described for me and those I found on the
> Wiki:
> 1: Downloaded latest trunk
> 2: Compiled GDAL (how many of the steps must I do? All? Or just the
> first, I guess just the first)
> 3: Created the C# interface and compiled it.
> 4: Copied the resulting *_wrap.dlls to Fwtool1.3.0\bin folder
> 5: Added the new CSharp-dlls to my C# project.
> 6: Checked that the system path contains FWTools1.3.0\bin folder
> If I try running my project after those steps I get an exception when
> trying to call GDAL, whatever *_wrap.dll that is called is not found/not
> possible to load.
> When I add the wrap-dlls to the "root" of my C#-project, no apparent change.
> When I copy the GDAL-dll to my projects root and include it in the
> build, together with the wrap-dlls, it works!
I my previous letter I've noted that with this setting the *_wrap.dll
will link to the gdal14.dll therefore this dll should also be
available for your application to load.
In my personal opinion if you would distribute your app with this
functionality you might include these dll-s in your package.
Apparently, in the same folder where your application resides.
> But is this how it now is supposed to be? I guess I with this setup can
> use GDALs basic function but all the functions which rely on other libs
> (which I have not tested/any knowledge of yet) are not available? For
> example reading and writing of GeoTiff images? (That is possible via the
> C#-bindings?)
> For now I think I'm content with coordinate translation but I think I
> want to try how efficient GDAL is to use when importing maps of
> different formats. It would be nice to be able to rip directly from
> GeoTiff (or RIK) with GDAL.
Most of the functionality of the GDAL/OGR core is exposed to the C#
interface. But indeed many of them might require further dll-s to
include (can normally be found in the FWTools/bin directory). In this
case you might add these dll in your application folder as well.
> Perhaps a bit OT but:
> In basic it boils down to that I have now not a clear idea how to
> distribute the plugin I am building. Demand that FWTools are installed
> or include the nessecary dlls? O well, there is time left to think about
> that.
It depends on the architecture of the application. In fact all of the
dll-s mentioned before should be available to load by the executable
either by adding the location in the PATH environment or copying them
in the application folder.
Best regards,
Tamas
