Has anyone been able to write 8-bit grayscale TIFFs using JPEG compression? I'm running into an issue where libtiff aborts because the photometric interpretation is invalid, even if min_is_black is used. Seems the JCS_GRAYSCALE flag never gets set by the driver. Using the JPEG driver itself is okay. Ray
