[Gdal-dev] Use of gdalwarp/translate utility
Doug Nebert
ddnebert at usgs.gov
Fri May 18 11:51:21 EDT 2007
I have a series of images that are 2000x2000 pixels centered on the
polar regions in a EPSG:3413 projection, though Proj.4/GDAL don't seem
to know about it yet. I'd like to take the GIFs and embed the
projection information in the TIFF header so that they may be
used/interpreted in applications such as transformation to other
projections.
I've been trying gdal_translate to do this assignment, and gdalinfo
seems to show some things being set. And yet, I am getting pixels equal
to units of measure, instead of meters.
The details of this unusual projection:
Based on Polar Stereographic (variant B) method
Base CRS and ellipsoid are WGS84
Latitude of standard parallel: 70N (where the plane intersects)
Longitude of origin: 45W (Greenland is centered)
so I figured I could assign these by hand:
gdal_translate -a_srs "+proj=stere +datum=wgs84 +lat_ts=70.0 +lat_0=90
+lon_0=-45" -of GTiff input1.gif quickscat1.tif
But my reported coordinates when panning around the image are in pixel
coordinates, not in meters.
What am I missing in the assignment?
gdalinfo says:
Driver: GTiff/GeoTIFF
Size is 1530, 1530
Coordinate System is:
PROJCS["unnamed",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Polar_Stereographic"],
PARAMETER["latitude_of_origin",70],
PARAMETER["central_meridian",-45],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Metadata:
AREA_OR_POINT=Area
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 1530.0)
Upper Right ( 1530.0, 0.0)
Lower Right ( 1530.0, 1530.0)
Center ( 765.0, 765.0)
Douglas D. Nebert
Geospatial Data Clearinghouse Coordinator, Information Architect
FGDC/GSDI Secretariat Phone: +1 703 648 4151 Fax: +1 703 648-5755
