[Gdal-dev] Writing 8-bit TIFFs using JPEG compression
Ray Gardener rayg at daylongraphics.com
Sat May 19 01:28:11 EDT 2007
Frank Warmerdam wrote:
> Ray,
> I just tried it and it seemed to work, though I see the following
> debug message, which I find suspicious:
> GTiff: Setting JPEGCOLORMODE_RGB
> Some of the jpeg stuff is very sensitive to the version of libtiff.  Are
> you
> using the builtin libtiff?  The last public release?  libtiff-3.9 from CVS?
This is with the built-in libtiff in 1.3.2. I didn't find any tiff
driver refs to JCS_GRAYSCALE in 1.4.1 but I should revisit the issue
when I've had a chance to upgrade.
Another thing I noticed that might be a higher-level problem is that if
the tiff copycreate() gets a color table from a one-band dataset, it
assumes rgb. But 8-bit formats w/o an explicit gray mode need color
tables to emulate it, and there's no way to tell which is which except
to fabricate a driver properties list ahead of time. A simple fix would
be to have the driver examine the color table and if it sees that it's
grayscale, then switch to gray mode.
Ray
