[Gdal-dev] Use of gdalwarp/translate utility
Tue May 22 12:36:09 EDT 2007
Doug Nebert wrote:
> In trying to use the gdal_translate on a non-standard projection, the
> hardest part I found was to determine what the allowable syntax and
> meaning of the PROJ.4 parameters were (i.e. +lat_0=70, +ellps=WGS84) as
> an argument to a_srs. I figured it out by googling some examples, but
> there is no clean list that I could find. If there is a list of such
> parameters, it should be linked from the gdal_translate page -- and the
> general GDAL page for that matter -- with the appropriate support for
> each projection. The GeoTIFF projections transform list is a great
> start, but still does not include the PROJ.4 syntax for each projection
> parameter. http://www.remotesensing.org/geotiff/proj_list/
Doug,
Unfortunately, there is no concise PROJ.4 reference listing parameters
for all projections.  This is a task beyond my endurance to take on...
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
