[Gdal-dev] Bug in Selection polygon from PostGiS (PostgreSql) - MapGuide Open Source
Mateusz Loskot mateusz at loskot.net
Fri May 25 12:56:12 EDT 2007
Maciej Skorczewski wrote:
> I see all layers correct but have problem whit correct selection of
> it. This are plans of rooms in building.
> I use Base Layers (Ajax Tile base) problem looks like this (look in
> print screen).
> http://img340.imageshack.us/img340/4928/bugpostgisey2.jpg
> when i try this same whit shp files all works ok (i can select this
> smaller polygon) ...so i thing that problem is whit Ogr provider, or
> maybe it is BUG in MapGuide.
Maciej,
I think it's hard to find where is the problem from your report.
Could you provide me with your shapefile?
Then I will be able to write simple test reproducing your steps
and then we can observe if OGR behaves correctly or not.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
