[Gdal-dev] GTOPO30 and max value
Ivan Lucena ivan.lucena at pmldnet.com
Thu May 31 07:52:08 EDT 2007
Markus,
I can see that you don't have one of those files, but since you mentioned:
>  I think when used with Arc/Info there was some information (like
> pixel type) that was passed on the commandline or something.
That is where they are created.
Good Luck,
Ivan
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Markus Neteler
Sent: Thursday, May 31, 2007 5:02 AM
To: 'GDAL-dev list'
Subject: Re: [Gdal-dev] GTOPO30 and max value
On Wed, May 30, 2007 at 05:08:20PM -0400, Ivan Lucena wrote:
> Markus,
> I found one situation where the AUX file was inconsistent with the AIG
> dataset. Gdalinfo was reporting correctly 'unsigned 8 bit', while ArcMap
was
> reporting 'unsigned 16'. I just remove the .AUX file and the problem was
> gone. Is it possible that you are facing the same problem?
Ivan,
I have no idea...:
tar xvfz ../w100n40.tar.gz
W100N40.DEM - DEM File
W100N40.DMW - World File
W100N40.GIF - Shaded Relief Image
W100N40.HDR - Header File
W100N40.PRJ - Projection File
W100N40.SCH - Source Map Header File
W100N40.SRC - Source Map
W100N40.STX - Statistics File
Not sure what could be taken as AUX file by GDAL.
Best regards,
Ivan Lucena
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
