[Gdal-dev] GTOPO30 and max value
Markus Neteler neteler at itc.it
Thu May 31 05:02:19 EDT 2007
On Wed, May 30, 2007 at 05:08:20PM -0400, Ivan Lucena wrote:
> Markus,
> I found one situation where the AUX file was inconsistent with the AIG
> dataset. Gdalinfo was reporting correctly 'unsigned 8 bit', while ArcMap was
> reporting 'unsigned 16'. I just remove the .AUX file and the problem was
> gone. Is it possible that you are facing the same problem?
Ivan,
I have no idea...:
tar xvfz ../w100n40.tar.gz
W100N40.DEM - DEM File
W100N40.DMW - World File
W100N40.GIF - Shaded Relief Image
W100N40.HDR - Header File
W100N40.PRJ - Projection File
W100N40.SCH - Source Map Header File
W100N40.SRC - Source Map
W100N40.STX - Statistics File
Not sure what could be taken as AUX file by GDAL.
Best regards,
Ivan Lucena
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
