[Gdal-dev] 'make install' and NG Python Bindings
William Kyngesburye
woklist at kyngchaos.com
Thu Nov 1 17:19:31 EDT 2007
Finally got thru the Leopard build. The swig python scripts are not
installed at all. From what I see in the makefile, the script install
is trapped inside the itest target, which isn't referenced anywhere:
itest:
echo $(SCRIPTS)
for f in $(SCRIPTS) ; do $(INSTALL) ./scripts/$$f $(DESTDIR)$
(INST_BIN) ; done
On Oct 31, 2007, at 11:10 PM, Howard Butler wrote:
> Chris and William (and others following along),
> I updated the 'make install' target of ./swig/python/GNUMakefile to
> install the contents of ./swig/scripts in prefix/bin, like the GDAL/
> OGR apps, etc. Please add to http://trac.osgeo.org/gdal/ticket/1962
> if any issues arise or I did something dumb.
> People seem to prefer the 'make install' approach of manually
> copying things as we did in the past, but I'm wondering if we don't
> also want to add "scripts" support to the setuptools side of the
> bindings and *also* install them that way. The only significant
> advantage is someone getting stuff from the cheeseshop would also
> get the utilities.
> Howard
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
