[Gdal-dev] How do I set up gdal_translate to recognize GSAG?
Evan Thoms
ethoms at usgs.gov
Tue Nov 6 14:41:54 EST 2007
Thanks Frank,
Right, I only had 1.4 and gsag was not a supported format.
I checked out FWtools and the driver's been added there.
cheers
Evan Thoms
Geologist\GIS Specialist
U.S. Geological Survey, Alaska Science Center
4200 University Drive, Anchorage, AK 99508
voice: 907-786-7409 fax: 907-786-7401
ethoms at usgs.gov
Frank Warmerdam wrote:
> Evan Thoms wrote:
>> Hi,
>> I need to convert an ascii surfer grid to a geotiff, but that format
>> is unsupported by gdal_translate without modification. I utterly fail
>> to understand how to add the required driver to the command. Can
>> anyone explain in 101 language?
> Evan,
> If you have the driver built into GDAL you shouldn't need to do anything
> special on the commandline. Just something like:
> gdal_translate your_gsag.asc out.tif
> You can verify you have the driver registered by doing:
> gdal_translate --format gsag
> The driver does not appear to be in 1.4, but is in 1.5 (aka
> svn-trunk). So
> you either need to build from subversion (or a nightly svn-trunk
> snapshot) or
> get development binaries (such as FWTools).
> Best regards,
