[Gdal-dev] How to measure a distance betwen two points on a line
Gustavo Ces
g.ces at pettra.es
Thu Nov 8 07:10:29 EST 2007
----- Original Message -----
To: "Jose Luis Gomez Dans" <josegomez at gmx.net>
Sent: Thursday, November 08, 2007 12:20 PM
Subject: Re: [Gdal-dev] How to measure a distance betwen two points on a
line
> Hi Jose
> Thanks for answering. I´d love to getPoint() but i can´t because my
> feat.GetGeometryRef() returned doesn´t have this method!
> feat.GetGeometryName() returns ' Linestring" and in ogr page i can see
> a getPoint() method for that type of class. May i have to convert my
> geometry to linestring ? How?
> Now i can access to point coordinates ( with GetX and GetY) but that´s
> all.
> I see a get_length too, but only for linestring classes... Snif!
> Gus
> From: "Jose Luis Gomez Dans" <josegomez at gmx.net>
> To: "Gustavo Ces" <g.ces at pettra.es>; <gdal-dev at lists.maptools.org>
> Sent: Thursday, November 08, 2007 11:58 AM
> line
>> Hi Gus,
>> -------- Original-Nachricht --------
>>> I´m making a python script and i need to measure the distance betwen
>>> two points on a line ( not the euclidean distance; sometimes there´s a
>>> lot
>>> of points betwen them...). I see the Distance() method but it seems it
>>> compares the euclidean distance betwen two geometries. Is there any ogr
>>> method
>>> to achieve my goal?
>> Maybe someone can provide more insight, but my idea would go along the
>> lines of using some sort of geoprocessing to split the bit of line
>> between your two points (you can use getPoint(point_position) to get your
>> point's geometry). In this resulting line, you can then measure its
>> length.
>> A similar way of doing this (skipping the geoprocessing bit, which might
>> be non-trivial) is to search for your first point (->getPoint(),
>> Equals()?), and copy that into a new line object, adding new points up to
>> your last point of interest. You can then use the
>> You don't want to use Distance, as that gives you the distance between
>> the geometries, not length along line, which is what you're looking for.
>> Hopefully, someone more knowledgeable than me will be able to help!
>> Jose
>> GMX FreeMail: 1 GB Postfach, 5 E-Mail-Adressen, 10 Free SMS.
>> Alle Infos und kostenlose Anmeldung: http://www.gmx.net/de/go/freemail
