[Gdal-dev] libtiff for Mac?
Eric Dönges eric.doenges at gmx.net
Thu Nov 15 05:15:34 EST 2007
Am 15.11.2007 um 00:24 schrieb Alison Luo:
> Is there a libtiff for Mac platform?
libtiff should compile for MacOS without any problems.
>  I need to call XTIFFOpenW equivalent on Mac, but this function is
> WIN32 specific.
I assume XTIFFOpenW takes an 16 bit Unicode string as input ? If this
is the case,
on MacOS you could create a CFString with either
CFStringCreateWithCharacters() or
CFStringCreateWithCharactersNoCopy(), use that string to create a
CFURL using CFURLCreateWithString(), and then call
CFURLGetFileSystemRepresentation() to get
the path in the proper encoding (which is UTF-8 on MacOS, I believe).
To avoid all
this pain, you should check if you can change your code to only use
UTF-8 for filenames.
Disclaimer: I only assume the above will work; I haven't tested it
myself.
With kind regards,
Eric
