[Gdal-dev] Method to get a google image by url?
Garrett Potts
potts at cfl.rr.com
Thu Nov 15 10:01:27 EST 2007
Hello:
I think for any http requests GDAL uses libcurl. There is a global
environment variable (I think) that you can set outside your software
for libcurl to go through a proxy. Let me dig around real quick
Take care
Garrett
On Nov 15, 2007, at 9:48 AM, Joaquim Luis wrote:
> Frank Warmerdam wrote:
>> If you have libcurl support included in your GDAL build you can
>> just do:
>> gdalinfo 'http://kh.google.com/kh?v=99&n=404&t=tqssrrqstt'
>> That is, GDAL has a special "HTTP" driver that will fetch from an url
>> and access the data from a memory buffer.
> Frank,
> Thanks that's cool, but before I dig out how to get the image in
> memory let me bug you with one further question.
> How do we declare a proxy?
> (you command worked at home but not here at the University -
> firewalls)
> Thanks
> Joaquim
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
