[Gdal-dev] Method to get a google image by url?
    Garrett Potts
    potts at cfl.rr.com
    Thu Nov 15 10:12:37 EST 2007
This is a cut and paste from the libcurl docs on setting a proxy
through the environment if the program doesn't expose it for ya to set.
the environment variable is http_proxy and they describe the format
of it here
Take care
Garrett
libcurl automatically checks and uses a set of environment variables
to know what proxies to use for certain protocols. The names of the
variables are following an ancient de facto standard and are built up
as "[protocol]_proxy" (note the lower casing). Which makes the
variable 'http_proxy' checked for a name of a proxy to use when the
input URL is HTTP. Following the same rule, the variable named
'ftp_proxy' is checked for FTP URLs. Again, the proxies are always
HTTP proxies, the different names of the variables simply allows
different HTTP proxies to be used.
The proxy environment variable contents should be in the format
"[protocol://][user:password@]machine[:port]". Where the protocol://
part is simply ignored if present (so http://proxy and bluerk://proxy
will do the same) and the optional port number specifies on which
port the proxy operates on the host. If not specified, the internal
default port number will be used and that is most likely *not* the
one you would like it to be.
There are two special environment variables. 'all_proxy' is what sets
proxy for any URL in case the protocol specific variable wasn't set,
and 'no_proxy' defines a list of hosts that should not use a proxy
even though a variable may say so. If 'no_proxy' is a plain asterisk
("*") it matches all hosts.
To explicitly disable libcurl's checking for and using the proxy
environment variables, set the proxy name to "" - an empty string -
with CURLOPT_PROXY.
http://curl.haxx.se/libcurl/c/libcurl-tutorial.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071115/d082d70b/attachment.html
