[Gdal-dev] Method to get a google image by url?
Brian Hamlin
maplabs at light42.com
Thu Nov 15 12:21:42 EST 2007
I am not pointing any fingers, but...
I was speaking with one of the Google developer relations people
yesterday. There is a problem in the field with downloading a lot of
Google's tiles and making things with them.. (I saw two examples) There
is a denial of service that kicks in at some point. Google is aware of
some of these cases, and is increasing scrutiny where appropriate.....
-Brian
On Nov 15, 2007, at 7:52 AM, Joaquim Luis wrote:
> Thanks Garrett
> Some search helped me to find that (in my case of course) this solves
> the problem (windows)
> set http_proxy=proxy1.si.ualg.pt:8080
> Joaquim Luis
>> I think for any http requests GDAL uses libcurl. There is a global
>> environment variable (I think) that you can set outside your software
>> for libcurl to go through a proxy. Let me dig around real quick
>> Take care
>> Garrett
>> On Nov 15, 2007, at 9:48 AM, Joaquim Luis wrote:
>>> Frank Warmerdam wrote:
>>>> If you have libcurl support included in your GDAL build you can
>>>> just do:
>>>> gdalinfo 'http://kh.google.com/kh?v=99&n=404&t=tqssrrqstt'
>>>> That is, GDAL has a special "HTTP" driver that will fetch from an
>>>> url
>>>> and access the data from a memory buffer.
>>> Frank,
>>> Thanks that's cool, but before I dig out how to get the image in
>>> memory let me bug you with one further question.
>>> How do we declare a proxy?
>>> (you command worked at home but not here at the University -
>>> firewalls)
>>> Thanks
>>> Joaquim
>>> Gdal-dev mailing list
>>> Gdal-dev at lists.maptools.org
>>> http://lists.maptools.org/mailman/listinfo/gdal-dev
